roper washer wont go to rinse cycle
My washer goes through all cycles but stops at the rince cycle whats wrong with it i think maybe water valve? ??
— Begin quote from stevencurtiss;905622
Your description is a little vague.
So are you saying the washer fills with water OK, then agitates OK, but fails to drain and spin in the rinse part of the cycle? Or are you saying something else?
Is it filling with rinse water? Is it draining and is it spinning? Do you have both cold and hot water? Have you checked your lid switch? Does it click when you shut the lid?
it does not rinse at all but spin an drain cycle works
[SIZE=3]Is it filling with rinse water? Do you have both cold and hot water? [/SIZE]
Yes both hot an cold no its not filling up to rinse i tried switching the silanoids around but that just made the water constantly run so I think im going to need a timer lid works an clicks good i also noticed the cold water valve is stuck open
