Noise and vibration on spin cycle
Hello! I am John, first of all I have not been able to locate the model # anywhere on the unit. I am using the model # from where it was purchased.(WPRE6150KWT). I removed the front panel and observed the cycles. During the spin cycle as it gets up to full speed it begins to get noisy then starts to vibrate moderately. The drum looks to be off center while looking into the unit thru the lid. All 4 rods and shock absorbers look OK including the top and bottom mounts. All rubber straps also look good. The belt is worn and needs replaced. The bottom pan is wet, but I can’t tell where it is leaking from. The pulley and castle nut look tight but, there is some slight play (a few thousants) in the pulley while pulling and pushing (side to side motion). The motor circuit board has what appears to be a constant blink from the LED. I do not see any noticeable pauses. I am thinking replace the tub bearing, belt and maybe the shift mode assembly. possibly even parts of the tub. What do you think? Thank’s, John!
