noise while on spin cycle
when in spinn cycle makes noise . belt is good
If a roaring noise, probably bad tub bearings, you can verify by turning the spin basket, and "rough" fearing is bad bearings.
Thanks but I took back off. There is a big pulley. Turned it left and right. Very smooth. I did see a hole in the tube above the shaft. Is that to oil?
If a hole right through the tub, you have a busted spider and soon the other two will break and the basket will jam.
