Washer makes loud bearing noise in spin cycle. Everything else works fine without any noise. It does not leak.
See if this technical bulletin from Maytag on your model addresses your problem.
http://www.servicematters.com/maytag_library/docs/TDL-0060-B.pdf
It is a somewhat time consuming repair and you need special tools.
