Which bearing to order?
Hello, brand new here.
I have the Maytag washer listed above and am getting a loud noise when on final spin only. It’s the kind of noise that say’s the bearing is bad. Question is which one? I have NO leaks at all so the seal is still good. I’m thinking it has to be the main bearing assembly since I have no leaks.
Am I on the right track here?
Thank you!!
It sounds like the bearing, except what you seem to be saying is that the noise is on the final spin only and not the spin after the wash cycle. So that is terribly confusing.
If it is on both spin cycles then you can click on your model number where you will be taken to parts diagrams for your model. You will also need a repair manual, but Maytag will no longer let us link you to one, so I suggest you see if you can find one on the internet for a small price and download it.
