hi! i have a problem with my washer. it makes so much noise when spinning, i tried to open it and i found a leak behind on the bearing where the spinner is connected. is there a way to change the bearing or it has to be change the whole spinning assembly? what parts should i replace. the leak is on the bearing itself. thank you!
Related topics
washer noisy | 3 | 1405 | January 19, 2009 | |
washer | 1 | 703 | December 28, 2008 | |
Which bearing to order? | 2 | 1064 | April 29, 2013 | |
washer makeing loud noise and leaks | 3 | 1522 | January 14, 2009 | |
Washer leaks and terrible noise at spin cycle.. | 21 | 12103 | November 3, 2009 |
