The washer has been making a loud bearing like noise for the last couple of loads and on the last load it started to leak a little. I was thinking it was the pump but how do I determine wheather it it the pump or the trans or some other bearing.
You have to remove the front panel to access all parts inside and pinpoint the leak.
Here are the break down diagrams for the Maytag washer http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=1356656&&model_id=5177282
I think the leak is at the seal at the bottom of the tub is their also a bearing there that could go bad
You can find the complete troubleshooting and repair instructions in the Service Manual.
Here are the break down diagrams for the Maytag washer http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=1356656&&&model_id=5177282
