noisy freezer fan
The fan to my freezer is noisy. The fan is turning, and the unit is working fine. I would like to replace the correct parts to remedy the noise problem. Not sure which parts to order. If I replace the condensor fan, will that help? I found two different diagrams for this model. One shows an evaporator motor behind the fan blade and the other shows a condensor fan. Please advise.
…no help, so I figured it out. I replaced the evaporator motor as well as the fan blade. The fan blade had a big knick in it, which could have attributed to the noise. The old motor still seemed good, but I replaced it anyway. I found discounted GE parts online and had them shipped to me. All is fine and quiet now! It was easy to do, but not easy to reach way back into the freezer.
