Not Able to Start but can cancel and pump water
Hi, pretty puzzled here.
Kitchen Aid KUDP02FRSS0
Age: not known came with condo
I can’t get the dishwasher to operate. I’m completely baffled. Here’s my facts:
1.) I tested all the buttons on the control panel with a multi-meter and they all work fine. Diode test brings from infinite to .74 on all.
2.) I ran the test/diagnostic by unplugging the owi sensor twice without the board plugged into P1 and it ran through the 16 minute sequence.
3.) The cancel button turns on the pump and drains water.
4.) I cannot get the diagnostic sequence to run on the keypad (I did once but it strangely only happened by hitting sani -> heated-dry twice. The manual says it should hightemp->heated-dry.) (???)
5.) The thermal fuse has continuity
6.) Holding start for 10-15 seconds causes "normal" wash to flash
7.) The door lock/switch checks out
8.) No burning on the board or circuits.
9.) Heavy duty, normal, light china, hightemp scrub, and sani rinse, start DO NOT light up when press (all cause ‘normal’ light to flash when pressed > 10 seconds)
10.) Quick clean up, rinse only, heat dry, 4-hour delay, and cancel ALL light up. (when held > 10 seconds, it causes their own light to flash)
11.) the time I was able to run the diagnostic with the keypad, it enabled me to run a normal wash - maybe because I reset the board somehow and cleared the normal and start buttons???
I’m lost on this and frustrated. A panel and control looks like it will cost $100-200 each and that doesn’t necessarily fix the problem. Anyone got any experience with this issue? This machine could be +10 years old.
Thanks - louee
