NOT control board problem
What could be causing the dishwasher to pump water in, then not do the wash cycles? It has been acting up. It did one wash cycle, then not the rest. Then pumps out water as it should, pumps back in water again. Goes thru a complete cycle, just no wash. Just won’t do wash cycle. It did one whole cycle right a week ago, but then goes back to no wash cycle again.
I DO NOT believe it is a control board problem. I got a used one and still have same problems. Can it still be a pump problem or can it be a sensor or something else? Just trying to get idea so I can see if it is worth fixing or not.
