Not sure which rear drum kit to order for GE DE6500GBL Dryer
Hi,
I’m in need of the rear bearing on my GE DDE6500GBL dryer because it’s squeaking badly after the dryer has been running for 1/2 an hour or so. I’ve read that you can oil the rear bearing but it might be best to replace the part. I found 2 part numbers for my dryer on the catalog at Appliancepartpros but I’m not sure which rear drum bearing kit to get. It looks like either WE25M40 or WE25X205 will work.
Thanks for your help.
