washer skips rinse and spin cycle unless i either open and close the door at the proper time or after washer has stopped i go back and manually set the switch to spin.
Hi.
Please, be more specific.
Thank you.
Simon.
Simon / APP Team said:
washer skips rinse and spin cycleHi.
Thank you.
Simon.
The timer skips over these cycles but works if i set it manually after the washer stops.
Thanks for your help.
Hi.
You need to replace the timer. To remove the knob push it in and hold the end of the shaft with needle noses, then pool the knob off.
The timer [part]27001113[/part]
Here are the breakdown diagrams and Replacement parts for Maytag SAV515DEWW WASHER-TOP LOADING | AppliancePartsPros.com
Thank you. Post the results.
Simon.
Ordered and installed timer and washer works perfectly.
Thanks again!
My pleasure.
Simon.
