I have the freezer works, refrigerator does not issue. I replaced the thermostat timer, turned off the unit and completely defrosted, and it still did not work.
I took out the evaporator motor, AP3845420 , and tested it for ohms. It reads OL when I test it. Can I assume that is the issue then? I am testing it completely unhooked and warm if that makes a difference.
Jeff
