oil under machine
motor mounting bolt fell out. reinstalled bolt and tightened the other two but there is an oily mess on floor. do i need to replace the oil and where is it from.
If a lot of oil on the floor, your transmission is failing, rather expensive to fix.
i,m fairly confident that reinstalling the bolt stopped the leak but i don’t know if the oil is replaceable.:confused:
If you don’t replace the oil, your upper bushing will fail. If you have a bench vice, you could support the tranny, take the cover off, and add some gear oil, or 40 weight motor oil. I think there is a part # for the right oil, but don’t know it.
