oil leaking on floor
I saw oil on floor, raised washer and found oil coming from area where motor shaft goes into grearbox. Is there a way to replace the oil seal where the shaft goes in? I do not see oil coming from the gasket area of the gearbox. The oil runs down to the bottom of gearbox and the rotating shaft slings the oil onto the cabinet. Will I need to replace the entire gearbox or can it be rebuilt?
    Thank you,        Gary McKee
