My Maytag washer is leaking oil onto the floor. Is there an easy way to fix this? I found a video on Youtube (https://www.youtube.com/watch?v=mz1aDPYey8o) that shows how to change the seal. If the seal is the problem, it doesn’t look too difficult to repair.
I don’t have the specs on that model, so I suggest you contact the parts department of APP (those of us who reply here are volunteers and do not work for APP) or contact customer service at Maytag and they should be able to give you that information.
You need to determine where the oil is leaking from. It could be the input shaft seal, the cover gasket or the seals at the spin pinion gear that protrudes out the top of the gearcase. If it’s a small amount of oil, I wouldn’t worry about adding more back in. If it’s a lot, then the only way to get the correct amount in would be to remove the top cover. Oil level should be just below the top edge of the lower half of the gearcase. This washer has the Maytag name on it but it’s made by Whirlpool. The correct oil to add is at this link.
You need to determine exactly where the oil is leaking from. Just because it’s dripping off the bottom most part of the transmission, doesn’t mean that’s where the leak is. It could very well be the input shaft seal and the oil is running along the transmission housing and accumulating there at the most bottom part and dripping off.
I’ve never taken this part of the machine apart before so I’m not sure how to dig further in to see where the oil is coming from. Are there any videos that would help with this area?
It’s leaking from the input shaft seal and just running along the bottom of the transmission and dripping from the lowest point. Your first diagnosis was correct. Just replace the input shaft seal. Unlikely that you’ve lost enough oil to worry about replacing any.
