Maytag Washer spraying oil under washer
Maytag Washer spraying oil under my washer.
I have a Maytag mav9501eww top load washer that I just replaced the tub seal/spindle, bearing and 2 white gaskets which took care of my water leak. When I tested the washer in the garage I noticed oil being sprayed around the bottom of the washer on my floor. Looks like the oil is from the transmission/belt area. My question is
1.) did I not tighten one of the bolts enough
2.) does the spindle need to be torqued more
3.) do I need to change a transmission seal under my washer?
4.) can I still find a transmission seal for my model if that’s the problem?
http://www.appliancepartspros.com/whirlpool-lower-seal-kit-207843-ap4024008.html
Transmission bottom lip seal kit, instructions included.
