Old Kenmore Side by Side Fridge Freezing!
I bought an old Kenmore side by side fridge, and noticed that the evaporator fan is constantly running. After letting the temperatures stabilize for 2 days, I am at 26 degrees in the fridge (freezer is around 0). I replaced the damper control assembly (Whirlpool #2209751 with a used part) and the thermostat (FSP #2203251 with a new part), and the fan still is constantly running.
The problem is, there is no wiring diagram in the front grill. I just was wondering where I could find a wiring diagram to see where the evaporator fan gets power from? I don’t believe these models have a circuit board. Or if anyone has ran into this, what should I check next? Thank you so much!
