Dryer spins but doesn’t heat… was wondering if there is a common part i could start with. I already tried the fuses. Its an older house so yes there are fuses. Any info would help thanks!
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=LER6634DW1
See the attachment for the wiring diagram.
As you can see there are a number of parts in the heater circuit.
You could check the heater as visually you can tell if it is blown.
If in auto modes the timer advances then the heating coil and the 240 volts are OK.
If the thermal cut-off is blown there are other parts that should be checked before replacing.
As far as a "common part", I would say a meter is where to start. It will let you check most parts in the heater circuit with the unit unplugged which is the safest way to do it.
- Always remove power from the machine otherwise you could blow your meter.
- Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path.
- When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale’s dynamic range.
