Only fills with hot water
My Whirlpool washer will only fill with hot water.I have replaced the water valve and still have the same problem.It also seems that it is not filling to the proper water level. Thank you.
Supply hoses hooked up correctly? If you select cold/cold and you get hot water, you have a faulty temp switch. As for the water level, remove the cabinet and check the air dome and hose on the lower right rear of the tub for gunk buildup. Clean as needed. If ok, check hose for kinks, splits/cracks. If hose is ok, replace the water level pressure switch and hose.
http://www.appliancepartspros.com/whirlpool-swtch-temp-8564140-ap3779164.html
http://www.appliancepartspros.com/whirlpool-switch-wl-w10339326-ap4568366.html
Eric
