Opening a Maytag Dryer to check interior parts
I am unable to open our Maytag dryer to check internal parts. Unable to pry top of dryer casing away from bottom of casing.
Here’s a parts breakdown of your dryer’s cabinet. You’ll see the screws in the lower front corners. Remove them and the front panel will swing up and away from the body. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=27387&diagram_id=874277#d874277
