This should be easy for some one who has worked on this machine. It’s a maytag commercial dryer and I cant see how to get the cabinet apart. Someone suggested I take off the coin holder and there was a nut . Well there was but it didnt seem to release the top. Any ideas. or where I might find a repair manual. I guessed at the age because it is in the apartment where I live.
Thanks for your help.
here’s a parts breakdown
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=29030
Nat
Try this: remove the screw on each side on the bottom of the front panel. Grab the front panel on the bottom and lift it up till about 45° to release it from the top fasteners. Open the diagrams and you’ll see what to do next.
Thanks Gene, I will give it a try in the morning, If I tried it now I might get kicked out for waking some one up.
thanks again, hope it works.
VErn
You are welcome. We are glad you were able to fix it.
