Ordering correct part number
I ordered part # wb21x226 I got wb21x5243 - the website gives ap2023620 for both. the terminals for the plug in terminals are a different size - I can’t install because of that–any way I can get the right part ? GE parts.com are useless. Right ,now I’m not worried about returns
I haven’t had any luck so far—If anyone has a part number or place where I could buy a replacement terminal adapter it would be appeciated.
1.) I had tried Radio Shack- no luck
2.) My friend the applicance repair man never had that problem.
3.) I used my rotary tool and ground down the terminal so I could slide the push on terminal on.
4.) I but it together and it didn’t work–A closer look on the instruction sheet said if your switch looks like Switch "A" (my switch) replace with Switch "B" Well switch "B" is not what they shipped.
5.) So I swapped switches with a front burner to a back burner. The cook rarely uses that back burner, so she is happy and I’m glad to be done.
— Begin quote from RileyBailey;500175
Riley,
The happy cook is the most important outcome. I’m surprised you weren’t able to find replacement terminals ? Everything changes, I guess.
You’ll be fine for a while anyway.
Good Luck,
The key pad flashes only the normal LED . Before this there was a noise. The tech sheet is gone. After unplugging it, the cancel drain worked for a minute and started flashing also. It cleared and then the normal LED started flashing again.
Any one help with this? It would be appreciated greatly.
By the way the unit won’t start.
Hi.
You need to replace the control panel. Chose the color on the diagram.
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5511551&diagram_id=29127935
Post the results.
Simon.
Thanks for your quick help. I hope you have a gread Lord’s Day!
Thank you very much.
Simon.
