Oven Blowing fuses
My oven when turned on, warms up for a while, gets to a certan heat, then blows a fuse. I’ve replaced the burner with a new one but it continues to do the same thing. Any ideas?
Steve
Does anybody have any suggestions? There doesn’t seem to be any wires burnt or touching. Besides, the fuse would blow right away if that was the case. Any ideas?
A Model Number may help someone help you.
Also you do not say if it is gas or electric.
Also is it a fuse or a circuit breaker in the mains panel that blows.
