oven /broiler will not lite
can t seem to get gas valve to open new gas valve ,new glow element,new control panel and heat sensor. gas to the stove works great
— Begin quote from buck1442;215725
…new control panel…
Which part did you mean? Can you refer to the numbers on the [Tech sheet](http://www.appliancepartspros.com/partsearch/model.aspx?model_id=502899&diagram_id=122827"]diagram[/URL]?
Are both Bake and Broil not working?
Here is the [URL="http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%209754241.pdf).
Gene I replaced parts 1&2 ap3178831 and ap3176181 of the control panel and yes the oven and broiler don t work the oven went 1 st 2 months later the broiler went control panel seems to work fine no error codes .Glow element also seems to work well thanks for any help!!!
i only replaced the oven glow element not broiler
Does it glow? How bright is it? Is it a brand new part?
yes it glows very bright and yes it is a brand new part
Gene any thoughts on what else i could check ?
Make sure the shut off valve on the gas pressure regulator (10 on the diagram) is open.
Gene that was the one stupied thing i over looked got the oven working may need to get a new glow element for the broiler thanks alot!!!
You are welcome. Most complicated problems end up being simpler than they seemed.
