The model # is MGR5770ADW on my earlier post of oven ignition and gas flow problem
In addition to your earlier post http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/14108-problem-oven-burner.html, the part number for the igniter is AP205873
Here are the break down diagrams for the Maytag range http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=642982&&model_id=45709
Thanks for the help Gene. The oven seems to be working now. Would the igniter be an intermentent problem.
Normally the current drawn by igniter should be between 3.2 to 3.6 amps. If it’s very close to 3.2 amps then it’ll work intermittently for some time until it dies.
