oven display dim
my JENN_AIR MODEL WW27430B CONTROL DISPLAY IS EXTREMLY DIM.
ALL THE FUNCTIONS APPEAR TO WORK. WHAT IS THE MOST LIKELY
CAUSE?
THANKS NICK
You did not include a model number but following is a post about the same problem.
http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/1058-thermador-display-very-dim.html
Since manufacturers do not publish circuit board diagrams I cannot say what capacitors need replacing though that info may be in the post somewhere.
If in doubt I would replace all of them. They are fairly cheap.
One thing to note is that they are electrolytic capacitors so it is important that the new capacitors be installed with the positive and negative legs positioned the same as the old caps.
How do you access the capacitor? Need to pull out the oven? I have a Thermador drop in RED30VQ
Boots49
I do not know how to get to the display on your unit.
Perhaps look it up on AppliancePartsPros and the parts breakdown will help.
If you click on a part’s picture a new page will open will a Q&A section which may have the info you need.
With luck someone else will jump in who does know.
You may also want to start your own thread asking this question using "Post New Topic"
