Oven does not heat
Our oven does not heat when we put it on bake mode. The broiler and cleaning cycle work fine but when we go topreheat the oven, it stays at 100 on the control panel and every now and then you hear a clicking sound. It is a maytag precision 500 electric.
In order to provide most accurate advise we need the complete model number of the range.
I believe the model is MERs751baw.
Remove the Bake heating element as far as the wires go and check for a burned wires.
Remove one of the wires and check the heating element for continuity.
Replace the Bake heating element if it’s open.
If there is nothing wrong then replace the control board.
8 Month Old, Has worked Flawlessly. Now, Does not fully Drain and leave diry water in the bottom. I took off the exhaust hose and stuck it in a bucket to rule out disposal/sink drain. Same problem. The exhaust hose is still secured securley High to the top of the sinnk. Any Suggestions would be appreciated.
Check the sump for debris.
If OK then I would put in a service call.
Why should you mess with it when it is covered under warranty.
