oven doesn't heat higher than 375 degrees
I have replaced both the ignitor & temp. sensor, but the oven still will not heat above about 350-375 degrees. I’ve replaced the ignitor in the past & saw an immediate difference, but not this time so then changed temp. sensor. Still no luck.:frowning:
Sounds like the problem is a bad control board. If you need the correct part number then post the complete model and serial numbers of the oven.
Thank You. The oven is a Maytag, mod# CRG9800AAE ser# 18703381KK
Is this something I might be able to change myself or is it going to be complicated & better left to a pro? After looking up similar parts to get an idea of price I was hoping it wasn’t going to be this, but I guess it’s still cheaper than a new oven… Thank you again!!
If I was able to manage the ignitor & the temp.sensor I guess I can give this a try. I didn’t think it would be too complicated, just wanted to be sure before I tried. I guess it still beats buying a new oven. Thanks Again!
You are welcome. Good luck and keep us posted.
I have a maytag range model CRG9800AAE serial # 10000247HB. The clock works but none of the oven controls work. Please help. Thanks
