Oven works but temperature way off.
The oven does heat but temperature is off -25 @ 200 and over -150 @ 550. Suspect AP4009456 oven sensor and would like to know the resistance/temperature values so that I can test it. The oven does maintain temperature but the temperature is incorrect. Another repair person suggested the ignitor so I swapped the ignitor from the broiler burner with the one for the oven burner. This had no effect. Seems to me that either the oven sensor or controller (yikes that’s expensive) is at fault. I would like to avoid just replacing the oven sensor since I’m not sure that’s the problem.
If it’s the controller, it’s time for a new oven as far as I can justify.
Thanks in advance,
Ah
