oven error display codes
hi,
My oven is not working. I tried to figure out what is wrong. I took tech sheet paper inside top of oven. My oven on keyboard said, E3 -F1. So, I look up at tech sheet paper to find what excatly problem. I can’t figure out what is E3 -F1? So can you help me?
Thank you, michael
Hi Michael,
It says in the [B]Tech sheet[/B] for all error codes with "F1" fault code: "electronic control malfunction", and recommended repair is to replace control. I would try to power off the oven for a few minutes first. Sometime it helps.
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=109811&&model_id=263109
