Whirlpool Built in Oven Fault Code - E2 F3
I need help determining a fault code we keep getting on our built in Whirlpool oven. Twice now when we use our oven once it preheats we get an E2 F3 code.
Could someone tell me what that code means and how we fix it?
Cannot find the correct tech sheet as the model number you gave is short several digits.
Below is an example tech sheet for a RBD245PDB10
[COLOR=Blue]http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%204451887.pdf
Sounds like a sensor problem but may also be the control board.
[/COLOR]
