:eek: Help! Just got my new stove today and the burners on top work great, but when you turn the oven on to 300 degrees flames shoot up inside. Do you need to change the orifice inside when you convert a natural gas to an LP? The top orifice was changed, the regulator was changed too but is there something else I’m missing??
loosen the orifice up you can see where the burner goes over the brass orifice you will see you can put a 1/2 in open end wrench and turn it you tighten it down for natural and loosen it up a few turns for LP do the same with the broil if its self clean
