Oven Locks Up; Can't Turn Heat Off; E1F2
During baking my oven locked up and temp went into high heat. Possibly went into self cleaning mode? Turned off the circuit breaker but the next AM when I turned the circuit breaker back on the oven started by itself and went into high temp again.:mad: An error code E1F2 appeared. We just received our ordered part CNTRL-ELEC Whirlpool: 8302994. The heat no longer turns on by itself but the error code E1F2 still appears. Can someone explain the error code?:confused:
Here are the parts
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=RBS305PDB14
Here is a tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208301757.pdf
Looks like the ribbon cable from the keypad to the board is not making a good contact.
Try the following.
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector.
