The oven will not heat up past 325,I can turn the boiler on for a few minutes and then turn the oven on and it will heat up to a higher temp.Sometimes when I turn the oven on to say 350 or 400 it will reach that temp.I have replaced the temp sensor and bake element. I am lost as to what the next move is Thank You
Related topics
Oven won't heat past 250 degrees | 2 | 3805 | June 8, 2011 | |
oven won't work | 0 | 1874 | October 8, 2009 | |
Oven still not reaching temp after replacing sensor and element | 1 | 133 | November 25, 2019 | |
Oven does not heat past 270 | 5 | 2369 | November 19, 2013 | |
Thermador SEC302BP 01 | 1 | 265 | November 13, 2019 |
