Oven set at certain degree; but oven is below settng
Gas oven - Set the baking dial to a certain degree and the alarm goes off indicating oven has reached it’s degree setting. Inserted an oven thermometer in the oven for a few minutes and its degrees is about 75 degress lower. HELP???:confused:
— Begin quote from acobag;709888
  1. check door seal for escaping heat , seal may be bad. 2. there is a setting on the oven control module wich is the main panel controls. This setting allows you to program the thermostat heat control for plus or minus temperature degrees in the oven. There is diagnostic paper work located in the top oven panel or down underneath the oven where the draw is located if you have this type of oven. in that paperwork it will show you how to adjust the temperature difference. If this doesn’t work for the time being then you most likely have a thermostat issue and the thermostat may need replacing. Not a difficult job to replace thermostat I hope this was helpful
