Oven shuts off within ten minutes
The oven shuts off usually within the first ten mins. Repeat turning on oven and have varied temp range settings. The oven will eventually stay on but will take many attempts
Hi.
When you say oven shuts off does the control board still shows Bake and temperature?
Does the display stay on?
Thank you.
Simon.
Temp. And bake displays are gone but clock and timer continue to work
HI.
Most likely it’s the control board 8507P229-60
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5517555
Post the results.
Simon.
Thanks Simon for your response, but I have some concerns about the control board. Do you think the heat from door is the cause, and is this going to be an issue every two years?
Hi.
Unfortunately the Maytag doesn’t give us any recommendations on this issue.
Simon.
