Oven slow and won't reach temp.
When baking, the oven never reaches the right temp. and is very slow and tops out at 190 to 210. Usually set at 350-400 for our stuff. What could it be, thermo, sensor, ignitor or board?
Thanks for your help,
Rugardave
Hi.
Your oven ignitor should draw 3.25amp to open the gas valve.
If it’s less than 3.2amp it will just seat there glowing, producing around 200*F.
The oven ignitor 9782065
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=503808
Thank you. Post the results.
Simon.
