Hi. I’m new to the forum and I almost trashed the oven before trying to see if it could be fixed.
The oven is a Kenmore 24 inch range that was in our home when we moved in about two years ago. It worked fine until earlier this year when it would not heat. Sometimes, it would heat up in time and I thought I would help it along by banging on the heating door…and it was amazing that the oven would ignite sometimes but now, it doesn’t.
I see a small yellow-red flame in the back, and it only comes on if I turn on a top burner. The left side of the stove won’t ignite without a match…I’m not sure what is going on or if it is something that can be fixed.
I have to have a stove this size because of space restraints so I’m inclined to try to fix it.
Any ideas?
