Oven temperature of 25 degrees
My oven does not heat to the correct temperature. It is consistently between 25 and 30 degrees low. Is there a way to recalibrate?
In case you have lost the operators manual. Here it is
http://shared.whirlpoolcorp.com/assets/pdfs/literature/SVE47500B.pdf
Check out Page 44
