Cook top works fine but oven will not turn on.
Is there a fuse or thermostat that controls this function.
I do not have a parts schematic or listing to go by to see what parts could be bad.
Any help would be appreciated!
The model number you posted is incomplete. Verify and repost it please.
Model number JGBP24EJH2
This model number does not come up. The closest model number I found is JGBP24GEJ2. Per this model number the range is gas. Is this correct?
That is correct, it is a gas oven.
Gene said:
This model number does not come up. The closest model number I found is JGBP24GEJ2. Per this model number the range is gas. Is this correct?Gene.
I have a similar problem with a GE Oven JGBC15GER4WH Itjust will not come on. How do you determine which part is bad?
Even your range is different you still can use the same instructions as Xray.
- The oven igniter AP2014008
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=213612
Will check to see if we are getting 120vac and then order ignitor if needed.
Thanks,
Greg
Thanks, Gene. I will check the voltage and order an igniter if the voltage is ok.
Bill(jwsbillie)
