frigidaire FEB27S5ABB model, wall unit. Worked perfectly until I went to clean the bottom out and bumped the lower burner. It was trying to heat up at first but would not reach max temp. Now both bake & broil elements wont work. The rest of the oven works. When I try to heat it up I can hear the clicking sounds in the control panel like it’s working normally. Tried resetting the breakers, no luck. HELP PLEASE
Related topics
Frigidaire oven won't heat | 3 | 984 | March 5, 2017 | |
oven wont work at all | 2 | 1248 | March 13, 2013 | |
No bake/broil | 2 | 1193 | August 15, 2008 | |
Oven will not heat, but everything else works! | 0 | 1367 | October 26, 2010 | |
Oven will not heat | 3 | 970 | November 12, 2015 |
