I am just moving into this house and the oven does not work. The burners up top work, but when I turned the oven on 400 degrees, nothing happened. I didn’t think to test the broil, I just freaked out!!! I need to know what could be causing this problem and how I could fix it. The goal is to try and avoid buying a new stove if I can. Ovens/stoves are not my area, so if you could explain in "dumby" terms I would greatly appreciate it!!!
thanks
