The oven will not turn off .When the off button is pushed nothing happens
Hi.
Does the control beeps when the OFF key is pushed?
Simon.
It does not
Hi.
Turn the power to the oven off and then back on in 5 min.
If the gas shots off replace the touch pad, if not - control board.
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5139479
Thank you. Post the results.
Simon.
Its the touch pad
