Oven will not work
The oven will not work and the oven control or not lit up but the stove top is working
Does the oven light work.
The elements use the full 240 but the contol board and oven light need 120 volts so perhaps you have lost Neutral.
I would start by checking the power.
Try flipping the breaker off/on slowly, sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
