Oven not working, at all
Needed to change bottom baking element. Was stupid and did not unplug it before I pulled out old element. Sparked :frowning: Now entire oven and stove top does not work. What do I need to replace now?
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=JBP78W0B1WW
You can see that there is not a unit with a 0 between the W and B.
Since both the oven control and the stove top elements do not work, it sounds like a power problem.
The two are usually separate circuits in a stove.
So I would start by checking the power.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
If OK then unplug it and check that you have not burned off a wire that is common to oven and stove top (very few have one)
I cannot tell if the unit has an internal fuse. It is a GE and they like to keep everything a secret.
Do not be surprised if when you get the stove top working that the oven does not.
This usually blows the control board/timer.
