Oven won't stay lit.
I am just sick, once before my oven had this same symptom, the burner lights right up but then shuts off after about 3 sceonds. Before I replaced the burner igniter element, 8190618, and it works fine. Recently the same symptom started again so I again replaced this part. However, now the over is acting the same way, it starts right up and then shuts off. In fact the other day when I received this part and installed itl, it worked fine. now a few days later it is not working again.
I am guessing that I may need to replace the valve which is rather expensive. What do you thinks please,
thanks,
mike puckett:confused:
