Ovenr Control/clock Clicking and not working
I have a Jenn-Air duel-fuel range (JDR8895AAS) and the clock/control touch pad is not working. It is clicking and beeping sometimes, but will not stay on. I have replaced the control panel with a new one and it did the exact same thing as soon as I turned the power on. Any suggestions? Is there a relay somewhere else or a place where a connection could be bad?
Thanks, Brian
Brian,
What does it show on the display?
What happen if you push any button?
I’m assuming you replaced the electronic clock/timer which you called "control panel"?
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5174617
[SIZE=3]I decided to check every connection I could find. So when I took off the lower back panel I immediately found the root cause of the problem. One of the power cord wires was very loose. It had burned most of the insulation off of the wire and almost burned the wire in two. It is most likely what caused the short in my clock. I clean the posts and replaced the cord. Everything works and all is good in my kitchen again. Thanks for the offer of advice. It is greatly appreciated!:smiley: [/SIZE]
You are welcome Brian. I’m glad you were able to fix it. Good job!
Thank you for the feed back.
