panel does not light up
I have a bosch shx56c dishwasher.
Problem:
I have power to unit, but the control panel does not light up. I know that I have power inside the unit, via the volt meter. The water is connected.
The orignal problem started when the impeller that is attached to the motor locked up due to salt from the softner system.
Removed the motor, cleared the blockage and reinstalled the motor. Put the system back together applied power, and now the panel does not light up. The on/off switch does not light up, etc.
lcoker
