I would like to find out how to remove the top and front panels of the dryer.
I cannot see exactly the configuration of this Frigidaire made model, but if the control panel sits on top of the cabinet, then you can release the top by inserting a screw driver in the gap between the top and front and prying up. The top will flip up.
If the controls are in the front, take out screws in the back of the top to take it off.
You can then remove the front panel by taking out screws that hold it to the frame.
